internet and minutes
leahprendergast
I bought the Don for €20 but have had no internet and my minutes are saying theyre gone even though theyre not...i have a huawei phone and my data roaming is on so i dont know what else there is to do??
got it working, was my first membership, but used your tweakker app and it works now, thanks :)tw
Did everything work before or are you new to 48 and this is your first membership?
Did you configure your internet settings for data/internet access?
Glad to hear you got it sorted.
bigjoeod
Regular
Was your last membership still active when you bought your new one? If it is you're gonna have to wait until it expires for the new one to kick in.
Till then why not buy yourself some addons for your account?
________________________________
If I helped you out, you can help me out by giving me 'Kudous' (The big thumbs up button) and accepting my answer as the solution to your problem.
Slowly putting the laughter back into slaughter..
