Texts
What add-on do I get if I want to send a text to a foreign number.? Thanks
Hi there
Check out this link below:
http://www.48months.ie/pricing
If this answers your question-please mark as solved!
Addition to the above post...
Just top up your balance to enable you to send international texts or calls outside of your membership terms.
(Check your 48 membership page-see 'balance')
Kkirrane
Follow up on your Query - has the reply post clarified the process of loading your balance to use for calls/texts outside your membership allowance?
Do post us back if you are still unsure.
There is no add-on. As mentioned above such texts are charged from your credit balance so you need cash credit on your account.
