Calls/texts don't work
KathleenK2922
I can’t make calls or text and no one can text me
KathleenK2922
Hi I’m not able to call or text
When was it working ok for you last?
Did anything change since then?
Phone software update, settings changes, factory reset/restore, returned from roaming abroad, etc.?
If not then if you do a manual scan for networks can you see and connect to 48?
What happens when you try to make a call or send a text?
Any error messages?
Can you receive calls?
Can you use mobile data?
