Sending SMS two times
paulboyle333
So i got a new phone the other day, Nexus 5. And ever since I started using it everyone I send a text message to repeorts back to me saying they recieved my messages two times. Whats the story with this?
I think that this (texts being sent multiple times) can happen when you are in an area of low/poor coverage.
On the other hand I have seen reports of people complaining of texts being sent multiple times on the Nexus 5 using Hangouts which may be separate from this? E.g.:
http://forum.xda-developers.com/google-nexus-5/help/hangouts-sending-double-texts-sms-t2522797
https://productforums.google.com/forum/#!topic/hangouts/bEEdKw8qDfE
(and many other links too...).
If you were on 48, with the same SIM, in the same area and on a different phone and you did not have this problem before but have it now with the N5 then it would suggest that it's the N5 which is at fault here...
Are you using Hangouts for texting?
paulboyle333
Yeah I was using hangouts, downloaded a stock SMS app and all seems to be fine now. Thanks
There are many reports of the Hangouts "multiple SMS" problem but no obvious fix.
One thing I've seen suggested is to clear the app's data/cache and maybe also switch the Android runtime from ART back to Dalvik. You could try that if you wanted to see if it helped you to get Hangouts working properly but if you are happy with a different messaging client then I guess it's not worth the hassle?
