help Internet not working
maryann14
my Internet is not working and my mobile data is on I also have 1.68gb left why would this be??
I presume it was working before now but just stopped?
Did anything change on your phone - e.g. APN/internet settings, software update etc.?
Do all other services work OK - incoming/outgoing calls/texts?
Did you try configuring your settings again? If the phone details in your post are correct then this link should work:
http://48months.tweakker.com/choose/Samsung/I9505%20Galaxy%20S4
If all else fails contact 48 support for assistance:
