Number
why did 48 give me a new number when i asked for my number to be moved??
When you join 48 you get a new SIM with a new 089 number.
http://community.48months.ie/t5/Joining-48/bd-p/__discuss
Once you get that you register it:
http://48months.ie/register-sim
Then you port your old number if necessary:
http://48months.ie/portin
Does that tally with your experience?
Billyh8603
Hi my old number did not come across
See here
https://community.48.ie/t5/The-Knowledgebase/Getting-Started-Move-Your-Number/ta-p/53100
If that doesn't work then you'll have to contact 48 support.
