3G
danielmatthews
Hey guys, just wondering why I can't get 3G at home? I have full coverage and I have gone through all the internet settings (iPhone 4S) and everything is the way it should be. Is there some sort of signal booster you can get or anything like that?
Cheers! 😊
Does it work when your outside your home?
If it does but not indoors then presumably your home is blocking the signal?
Do calls/texts work OK indoors?
Does it switch from H/H+ to 3G or something like that when indoors?
If that's the problem then you might be able to shop around for sound sort of indoor signal booster but I doubt that 48 can recommend anything and I'm not even sure if those devices are legal here?
