Internet
themilkman
My Internet isn't working great I have to sign in and out few times to get it to work please fix this problem
Did it ever work OK?
If so when did it start causing problems?
Did anything change - e.g. software update, settings changes etc.?
What exactly do you have to sign out of and back into to get things working?
Check that your internet settings are configured correctly:
If necessary post them here (screenshots are the best way if possible) for review.
Also if necessary you can contact 48 support directly here:
