How to enable LTE on smart watch?
GeorgijusG1108
Hello. please help me connect the LTE function for smart watches.
Thanks
You need to configure the APN settings correctly:
Check the watch manual to find out how to do this.
Most likely there is some specific app to do this or else you connect a web browser to the watch's admin control panel.
Angelag1735
Hi there.  Did you get this sorted? Trying to get the SIM working on a Tapo Camera
Did you configure the APN on the device with the SIM installed?
Are you sure that the Tapo C510W camera takes a SIM?
There's no mention of that feature here:
