Smart watch
mizzoni246
Hi im thinking of purchasing a lg 118 smart watch but was wondering if could get a micro sim card for that but be able to keep my nano sim activated and still working in my iphone 5/5s
If you mean two SIMs on the same account using the same number, membership etc. then I don't think that 48 support that but ask 48 support to be sure:
If you mean a separate SIM for the watch that would be on a separate number, account, membership etc. then that should be possble but you will have to buy two memberships each month and so on so maybe not the most practical solution?
mizzoni246
Yes it did thanks
Glad it did.
