09-01-2025 02:05 PM
Hi guys,
I ported my number from Vodafone to 48 on the 4th of December. SInce then, i have been having the issue of not getting calls from certain numbers. At any other time, I wouldnt mind and wait till its fixed but this is a very crucial time as i'm actively applying for jobs and interviewing.
I have already missed one very important job opportunity as a result of this and one which is very tenative as the recruiter is getting annoyed they can't reach me all the time. I'm raising this here because I also missed a delivery of some timely stuff for 3 days because i thought the driver wasn't calling when he was calling multiple times but says number cant be reached. I actually wish i didnt port or ported at a time when it wasnt really important.
How can i get a timely solution to this as it is very inconvenient at this particular time.
09-01-2025 02:24 PM
If it's an iPhone then maybe this will help?
Is there anything common between the callers whose calls don't connect?
What happens at their end when they call?
Voicemail? Error messages? Etc.?
09-01-2025 03:05 PM
I use an iphone xr.
I can't really tell the network they used but im assuming I easily get calls from 48 numbers.
I have done all those steps with my phone and i don't think anything has changed because i would usually test with a website that requires an otp which stopped working after i ported. I alwasy received when i was with vodafone.
I contacted 48 but there weren't much help as they said it was from vodafone. I contacted vodafone and they also said they couldnt be of much help because they have no way of helping as im not on their network. When i asked the delivery driver, they said it says number doesnt exist or something similar. Will it be worth just getting a new sim?
09-01-2025 02:56 PM
I use an iphone xr.
09-01-2025 03:12 PM
No harm in trying a replacement SIM but I wonder if it's more of a routing issue than a SIM issue.
Not sure what else you can do to be honest.
09-01-2025 03:20 PM
Thanks for the advice. I'll order a replacement sim. Do you reckon i order one with the same number or a comepltely different one?
09-01-2025 05:11 PM
Order a replacement and not a brand new SIM.
See here:
09-01-2025 05:24 PM
Thanks I'll do that now
