Visiting Greece for a few months - can I get unlimited data?
CaoimheB4896
I am going to Greece for a few months and looking to get unlimited data while there
48 don't offer unlimited EU roaming data.
The €12.99 plan comes with 17GB of EU/UK roaming data.
If you use that up then your can buy a data add-on to continue using roaming data:
However, bear in mind...
AaronS6679
Regular
You also have the option of getting an eSIM from multiple apps on the App Store or Play Store, if your phone supports eSIMs.
I’ve only tried GoMoWorld but there’s GoMoWorld, Airalo, Airhub, Nomad, Yesim etc.
