No mobile network past two weeks
LilijaV8115
Why has my phone not been working for 2 weeks and I am completely without communication. I have no internet or mobile network
Is this related to this previous issue that you posted about?
As you can see there I replied with some comments/questions but you never replied to clarify further.
Do you mean that everything was working ok two weeks ago?
Did anything change between when it was working and when you started having problems?
E.g. phone software update, settings changes, factor reset/restore, new phone handset, returned from roaming abroad, etc.?
If you do get a network connection does anything work - incoming/outgoing calls, incoming/outgoing texts, mobile data?
