tiny deal phone
hello,i got my smart phone on tiny deal from china,and i not understand how i can get a internet, phone would be  model F5 GSM/GPRS TV WiFi 850/900/1800/1900MHZ, GSM Quad band Cell phone,and phone looks like a real apple smart phone,its like a copy 🙂 maybe somebody have the same promblem like me
If it runs Android then try Tweakker APN:
In the (unlikely?) event that it does not run Android or Tweakker APN doesn't work then you'll need to find out how to manually configure the APN/internet/MMS settings and follow one of the existing settings in the above thread as a guide.
