signal only with wifi on
amandaomi
Updated nexus 5 to 5.0. Coverage bar has exclamation mark in it since. Receiving no notifications, emails, no access to Internet, etc unless I have wifi connected. Coverage bar has no exclamation mark with wifi connected. Phone also dropping signal, in that case I manually sign back into 48, with above issues still remaining. Any ideas/suggestions? Thanks
Sounds like the update may have lost your internet/APN settings and you need to configure these again and enable data roaming.
See here:
KateM8091
KateM8091
hey, having the same problem and changing the APN didnt work.
What problem exactly?
No signal/network connection at all?
If so then if you do a manual search for networks can you see and connect to 48?
Did this work before?
Or are you just joining 48?
Is the SIM activated?
