nokia lumia 520
i have a nokia lumia 520 and the settings are not here to get internet tried other settings and its not working. can you send settings to my mobile number
6 REPLIES 6
You mean you tried these generic Windows phone settings?
http://community.48months.ie/t5/Need-Help/WINDOWS-7-PHONES/m-p/214#U214
If so and they do not work then you might need to log a support request to get 48 to assist you:
tried that but that code doesnt bring up the mfg password prompt, i sent a message to 48
thanks
Ok - hope you get sorted. Maybe the Windows phone internet settings FAQ needs to be updated if it didn't work for you...
Good luck.
i'm having exact same prob with nokia lumia 800 when u enter the digits it's just bringing up a diagnostics thingy
Probably best to log a support request to get 48 to assist with this so...
buster
The settings for windows 8 phone is what you need to use for your Nokia Lumia 520 phone. Worked perfectly for me
