replacement sim
Im after loosing my phone. Would i be able to get a new one with my old numbet?
Yes - just log into your online account and click here:
That will deactivate your old SIM and order a replacement linked to your existing number/account/membership etc.
Hi ! Yup it's all very simple ! Basically you need to login , click into your profile , scroll down till you see the Help Stuff and click on Order Replacement Sim ! There you will cancel your previous sim and order a new one with the same number ! Sorry to hear about your phone btw but don't worry you haven't lost your number 🙂
