Internet Settings for Nokia Lumia 520
zyniu
hello. Could you send me setting for the internet for nokia lumia 520. Thanks
I think that you'll have to use the Windows 7 settings above as a guide to configuring your phone. If they don't work or your cannot figure it out then you might want to log a support query to ask 48 to assist you.
buster
I used settings for Windows 8 phones for nokia Lumia 520 and it done the job
