mobile internet
mobile internet is not working in my mobile
Did it work before and just stop? If so see this thread and maybe log a support query:
http://community.48months.ie/t5/Techie-Updates/Issue-with-some-customers-losing-3G-connection/td-p/1...
If it never worked before then you need to configure your internet settings and have a data allowance as part of your membership or add-on. Try all of the steps here:
