Moving my number
ariana28333
Hi. Followed all the steps for moving my number and its been 2 hours but no change? Could you check if everythings ok? Or if ive done something wrong?
Thank you!
Have a look at this:
How do I keep my old number?
If it's taking much longer than 2 hours (of porting business hours!) then log a support query to ak 48 support to look into it for you.
