help keeping same number
I never got my text saying I have kept my same number and to tell me what to do after..
Do I insert my 48 sim first or stay with my own now for the time been while its working?
Log into your online account.
What number is displayed?
If it's an 089 number then it's presumably a new number for the SIM.
If that's the case then you should be able to request a port of your old number:
How do I keep my old number?
If there are any error messages or this does not work then contact 48 support for assistance.
