Blacklisted Phone
Will a phone thats blacklisted on the 02 network work with a 48 sim?
How exactly do you mean blacklisted?
Do you mean barred because it's nicked out something?
Easiest way to try is to get a SIM, register it and try calling the new 089 number allocated to it.
