credit voucher
Payed 20 euro in shop for credit.. completed step 1 and 2 nearly 2 hours ago and still no credit
You have topped up your credit balance but you haven't bought membership yet.
That's why you can't make calls or send texts.
You need buy membership in order to be able to make calls, send texts etc.
Everything about membership
Hope  this helps.
Steps 1 and 2 where? Here?
What is your credit balance?
Log into your online account or dial *100# and hit call to check.
If it's €20+ then the topup worked.
Perhaps the issue is that you still need to buy membership?
How do I buy stuff by text?
Balance is 20.01 and still cant ring or text
Hope  this helps.
