internet
rossyroo
internet very slow over the last week, trouble shooting not working and my room mate has the same issue
You should log a support request to see if 48 support can assist here:
Edit...
Did it work OK before?
Did anything change?
Are your internet/APN settings correct?
I've seen cases of data access working but really slowly when these settings were misconfigured.
If necessary reconfigure them using the online configurator or (if on Android) the Tweakker APN app:
Internet Settings
Edit...
Internet Settings
