can't unsubscribe from spam messages because 48 won't let me txt the unsubscribe number
basscase
Is there any way to unsubscribe to services that send ads such as dominos that say "text stop to 51500". 48 wont let me txt those numbers?
48 does not support sending texts to premium SMS (PSMS) 5XXXX numbers so sending STOP to 5XXXX will not work.
You will have to try contacting the sender some other way.
I did this with one such number and managed to get them to stop and it worked.
Contact Dominos some other way to ask them to stop.
If they don't report them to ComReg.
