Spam sms GSpiderweb
ipjr
Hi,
I am recieveing spam sms. It does not come from a number but from somethng called " GSpiderweb "
There is no option in the message to unsubscribe from these.
Can you tell me how to block these messages?
Thanks
You'll have to get onto the service provider whoever they are and ask them to stop sending such texts.
These links might also be of relevance:
https://www.dataprotection.ie/docs/Guide_to_dealing_with_Unsolicited_SMS_messages/406.htm
https://www.digitalrights.ie/dealing-with-sms-spam/
http://www.citizensinformation.ie/en/consumer_affairs/telecommunications_and_postal_services/dealing...
Hi,
I contacted the sender, but they are still sending these messages.
Can you block them in any way?
How can someone send an SMS as a name but no number?
Thanks
There are various ways to send SMS messages while hiding the originator number.
If you have asked them to stop but they are still sending them then you should contact ComReg for advice.
https://www.comreg.ie
Did that help at all @ipjr?
