How do I send a text to a EU MOBILE ..I just topped up by 2 euro
garrymc
Once you have credit you can text as normal. It costs 25c per EU text. Don't forgot the international and country code prefixes - e.g. 00 33 for France, 00 44 for UK etc. And you may need to drop the leading 0 of the mobile number. Bear in mind that international MMS/picture messages are not supported. Some phones may convert long text SMS messages into MMS automatically. If you cannot get it working then contact 48 support:
garrymc
Thanks ...message seems to have been sent ..thanks for help
Great - glad it worked.
