can't ring 1580 numbers
leona2014
Why won't my phone ring1580 numbers since i changed to 48.
Unfortunately not in this case.
As I said 48 simply don't allow texts to be sent to 5XXXX numbers at all.
There is no add-on for this and having cash credit won't help in this case.
They simply don't allow it.
6 REPLIES 6
You need cash credit on your account.
50c per call for 1850 numbers.
See here:
Other call charges
All the other call charges
Free / Low call
NumberRate
1800 numbersFree
1850 numbers50c per call
1890 numbers50c per minute*
grainnemhaille
Tried to text 51551 but it wouldn't send, I still have my free text allowance?
Nothing to do with your text allowance.
48 simply don't allow texts to be sent to "Premium" SMS (PSMS) 5XXXX numbers at all.
Hi, many thanks for your reply. I am srill geting used to 48, so if I wish to text to a number that 48 does not allow from my Plan, can I buy cash credit and send that way? I like to text radio programmes at times to comment.
Grace.
Thanks again. Yes you have explained it perfectly.
