05-06-2015 11:29 PM
05-06-2015 11:43 PM
Probably the iPhone roaming problems yet again unfortunately... ![]()
If you do a manual scan for networks do you see any?
Can you connect to any?
Maybe try this in case it helps:
06-06-2015 10:39 AM
10-04-2016 01:29 PM
10-04-2016 02:41 PM
10-04-2016 10:50 PM
Any update/clarification on your problem?
11-04-2016 11:35 AM
11-04-2016 11:56 AM
Did you have any network coverage at all?
Were you able to search for and connect to a network in Scotland?
Was roaming enabled?
Did you have cash credit or EU roaming add-ons to cover the cost of sending texts?
Could you make/receive calls?
11-04-2016 10:07 PM
