going to england tor a weekend
pudz2015
ill be going to england for a weekend next month , will my membership or internet work over there on a basic membership plan ? if not what do i have to do ?
You will need membership for anything to work.
With just membership and nothing else you can receive texts.
But to make/receive calls or send texts you will need either cash credit to cover the costs or you will need an EU roaming calls and/or texts add-on.
http://community.48months.ie/t5/Most-Popular-Questions/Going-away-Using-48-abroad/m-p/46
48 don't support data while abroad so you will have to use wifi where available.
If you use an iPhone then you'll need to be aware of this issue:
iPhone abroad issue
Deleted - ignore.
