Phone constantly drops calls
maddladd
Hi,
I've been with 48 since last September- the network constantly drops calls- sometimes 2/3 times a day and 2/3 times a day I will have to enter my sim pin as if it has been turned on and off- any advice?- this is a constant prioblem so much so I'm thinking of leaving 48- I also never have 3g coverage band it's not the phone as another sim works fine.-
Thanks in advance
I've never had this problem myself.
Which PIN do you have to enter? SIM PIN[1]?
Might be a problem with the SIM?
Maybe contact support
and/or get a new SIM to switch over to and see if that helps.
Improvements to registering and changing your SIM
