Number wont transfer
slappytheseal
Hi my number has been tranferring the last 2 days now, I can still call and text on the old sim if that matters. Whats the hold up? Also the submit a request thing wont work for 48 help
Do you get an error when you try to log a support query online? What is it?
If that doesn't work then email them and mention this problem plus the number porting problem:
support@48months.zendesk.com
Hope this helps
Hope this helps
