internet not working
t8t8
Hi, ive got a sony experia z and the internet doesnt work,i can make calls and texts any help??
You'll have to configure the settings for this to work (and obviously have a membership or add-on with a data allowance).
Start here:
Internet Settings
Try the online configurator:
http://48months.tweakker.com/choose/Sony
If that doesn't work (some people including myself never receive any text from this!) then try the Tweakker APN app if possible:
If that doesn't work try manual configuration (don't forget to enable data roaming):
Internet Settings
If that doesn't work post the settings that don't seem to work here so others on the forum can review them for you.
And if all else fails contact 48 support for assistance:
