Need micro SIM, currently have regular SIM with 48 months
Hi there, i am using regular size sim and got Galaxy S3 phone now, it takes mini sim. How can i manage this?
I was advised to block my current sim and request the new one. I believe there must be other solution rather than staying without calls for 2-3 days.  Thanks in advance
@linag wrote:
Actually 48 support offered solution - NOT to cancell current SIM, order replacement SIM ...
Just to be clear DON'T order a replacement SIM here:
as that will block your existing SIM immediately.
Instead order a NEW SIM here and proceed as I described above:
http://48months.ie/free-sim
11 REPLIES 11
iPhone 7 takes a nano SIM.
If you don't already have one then you can order a replacement trio SIM (which is a nano inside a micro inside a mini inside a standard - you pop out the one that you need) here:
Need a new SIM?
