Membership Payment Problems
It says I have paid my membership, but it's not appearing in my history or allowing me to call or text.
I don't want to buy another membership and get double-charged, that has happened before.
What to do????
You should log a support query to get 48 to look into this for you:
By the way - if you buy a second membership then you are charged again but the membership gets stacked to kick in when your current membership expires so you don't lose out. "Double charged" makes it sound like some sort of rip off. It's not. But in any case I don't think that buying another membership now is going to help.
11 REPLIES 11
It did take two months worth of membership out of my bank account but only got one months membership. So yes I was double-charged and ripped off
OK - if that happened then it's obviously a mistake and you should get 48 support to sort it out:
SiobhanC2065
Won't take visa debit card,it's just saying visa or MasterCard when I try buy a membership
What happens if you select Visa and enter the debit card details?
Does it give an error message?
I can't remember if it only allows credit cards but maybe that's the issue?
Says here that Visa debit cards are accepted...
https://community.48.ie/t5/The-Knowledgebase/All-About-Memberships-and-Payments/ta-p/53105
colettes
I have had auto renew on my membership this ages but got a message this morning at 2.02 to say it didn't work. Card etc is fine, why would this happen?
You'll have to contact 48 support and ask them about this.
Nobody here on the community forum will be able to tell why this happened.
Appears to be back working now (21/5/2021 - 1PM)
