I want to upgrade new membership before current will expire
gosia
My current membership will expire in a week, so i decided I will buy the done today specially that i run out of the internet. But after i bought it it shows that it will starts after the first membership will end. Do I have to wait ???
Yes you have to wait.
But you can buy a data add-on in the meantime.
See here:
http://community.48months.ie/t5/Need-Help/mebership/m-p/31663#M10320
bought alredy 3 times landline minutes... it's pointless to buy internet. Why do have to wait? 😕 thats silly
I don't understand - why do you consider it pointless to buy a data add-on if you have used up your membership data allowance and need more to tide you over to the end of the membership month?
Membership always lasts a month and a new membership never prematurely ends a current one - that's just the way that 48 membership operates.
Everything about membership
If somebody is using up some or all membership allowances before the month is up then perhaps another type of membership would be more suitable for their needs so that they can avoid the need to buy add-ons?
Hi,
Is there any other membership that the standard one at 10.99?
I would like to have a membership with unlimited internet access
Why can't I find any info on that ?
Memberships are documented here.
It's even a stickie in the Featured Topics section at the top of the community forum so I'm not really sure how you couldn't find it...
https://community.48.ie/t5/The-Knowledgebase/All-About-Memberships-and-Payments/ta-p/53105
There are some legacy memberships that are only available to users who were on them originally and not to new users but none of them offer anything close to the current €10.99 membership's 100GB.
There is no membership with "unlimited" data.
