Configuration
foxy2650
I have asked for a configuration message from tweaked as I can't send texts or mms. I have credit. I put in the correct phone number my package was just renewed yesterday. Samsung Galaxy s5.
13 REPLIES 13
foxy2650
3 time's o have gone through it but no comeback.
Your post and issue are unclear.
What is you problem?
What are you trynng to do?
What is not working for you?
foxy2650
I can not send or receive texts or mms. I have asked for a configuration message from tweaker 3 time's but I'm not getting it.
To configure your internet settings follow the instructions here
http://community.48months.ie/t5/Other-Help/Internet-not-working-on-HUAWEI-ASCEND-g6-u10/m-p/34493#M1...
You also need cash credit to be able to send MMS messages.
30c each.
If you cannot send texts and you still have a text allowance via your membership or add-on then that's a separate issue that you'll have to contact 48 support about.
foxy2650
Yes thanks. I contacted 48 and they had to sort it for me.
Glad you got sorted.
You mean 48 had to deal with the SMS issue?
I presume that configuring your internet settings and adding cash credit allowed you to send MMS messages?
foxy2650
I already had cash credit and after cleaning the simple card I could send sms but still no mms.they sent me some android settings which sorted out the mms problem.
The link that I posted eartlier would have allowed you to configure things correctly for internet and MMS to work.
