Can't make calls or send texts
mellywellywilmot
My memberships not due to be gone and I can't make calls or send texts what is going on please fix it as I need it ?
Did it work before and then just stop?
Did you get any emails/texts from 48 about your membership/usage?
Any chance you breached the fair usage limits and got barred for the remainder of your current membership month?
Can you receive calls/texts?
If all else fails - as mentioned above - contact 48 support for help.
6 REPLIES 6
Your best option is to log a support request.
http://48months.ie/help/ask-agent
willr0526
Set up phone to make and receive calls in UK. New back in Ireland and can't make or receive calls what to do
Anything useful here?
https://community.48.ie/t5/The-Knowledgebase/The-Roaming-Troubleshooting-Guide/ta-p/52179
DiegoB3174
How did you solve? I have the same problem
https://community.48.ie/t5/Other-Help/new-member-can-t-make-calls-or-send-texts/m-p/58081/highlight/...
