48 website
mangis
I need to register my new Sim because I lost my old one... I deactivated the old one and now need to activate the new one.. But when I log in and press on the 'Activate replacement Sim' the page loads up blank... I tried this on multiple devices
dc888
Crew (retired)
Crew (retired)
Hey mangis
Can you contact the care crew so we cna sort this out for you.
Give it one more try and if it still does not work get in touch here http://48months.ie/help#ask-a-48-agent.
Send in your mobile number, full 19 digit SIM number and we will get you back up and running as soon as we can.
Damian from 48
Somebody else here had the same problem.
http://community.48months.ie/t5/Techie-Updates/Try-out-our-new-responsive-website/m-p/32223#M2239
Might be best to log a support query to ask 48 support for advice?
dc888
Crew (retired)
Crew (retired)
Hey mangis
Damian from 48
