SIM not working, no internet, no outgoing or incoming calls
ME6759
You'll need to post more info if you want assistance from the Community Forum.
Was everything working OK before or are you just getting started with 48?
If the latter then you should review the Getting Started FAQs in case they help:
Did you successfully activate your SIM?
Are there any error messages shown on screen when the 48 SIM is installed?
Can you receive calls, send/receive texts, use mobile data?
ME6759
Membership due for renewal 6 September,
no data texts or calls used from allowance
No signal, no ability for anyone to contact me
Have automatic renewal
See my previous reply and please provide the information requested:
