Incoming & outgoing calls not possible; membership issues?
jojojacob
I went on holiday, after returning had initially no problem. Soon after, was not able to make or receive calls (or use the internet) with it saying I needed a new membership, though I had still half a month of it left. Possible membership issues? Or perhaps a problem with my sim? Would appreciate advice on this. Btw, after returning home from holiday, I turned off roaming, via the 48 sim menu, so all good on that front.
What does your My48 account Dashboard say about your current membership plan status, allowance balances and expiry date?
Do you have a connection to the 48 network?
If you get a network connection then what happens when you try to make a call or send a text?
Any error messages?
