Unable to turn on sim pin lock
Davidt0594
I’ve an iPhone 11 and im unable to turn on sim pin lock using pin 1
Im getting the error unable to lock sim
I’ve 1 attempt left
Also will my puk code definitely unlock my sim
Here's how to enable SIM PIN locking on an iPhone.
You must be using the wrong PIN.
Enter the wrong PIN again for the third time and then use your PUK to unlock the SIM and then choose a PIN that you'll remember.
Thanks for reply
It’s pin 1 stamped on the physical card that came with my sim
4 digits i dont see how it can possibly be wrong as the puk code on it is same as the puk code in my account
I won’t be making a 3rd attempt at the moment i simply couldn’t risk the puk not working and having no phone
The PUK will work if you enter the PIN incorrectly a third time.
If you don't believe me then contact 48 support for further assistance.
