SIM card not registered
adejokeo7303
Sim card not registered
You'll need to post a bit more info if you want assistance from the Community Forum.
Was it ever working before?
Or are you just joining 48?
If you're just joining then you should review the New to 48 FAQs:
Did you successfully activate the SIM?
Are there any error messages when you log into your My48 account?
Have you tried reseating the SIM in case it's not inserted/seated correctly?
If the SIM is faulty then you'll probably need to try a replacement:
