Roaming not working
pavithrag4887
It’s shows I’ve roaming
But my roaming data isn’t working
What country are you in?
Only EU/UK are covered by roaming data allowances.
In some other countries you can use mobile data but have to pay for it from the cash credit balance on your account:
For roaming issues the usual general advice applies...
