Roaming won’t work
NiamhO2396
Good morning, I have noticed I’ve been abroad a couple of times now and my roaming doesn’t work. I’ve been to the UK last August and it didn’t work. I’m going to France next month and I need my phone. Can you help? I have never had problems before with a provider just turn on my phone and it automatically switches over
If I was you I would have a plan B prepared just in case - e.g. getting a local SIM for the trip or something like that.
