Help me
GayleD4245
I’m in Portugal using a 48 physical SIM. Calls and SMS work, but mobile data doesn’t. My iPhone 14 shows ‘Could not activate mobile data network’ while connected to MEO. Data Roaming is on. Please check that EU roaming data is provisioned on my account.
Are your APN settings configured correctly?
There's no "EU roaming data provisioning" on 48.
It should just work.
