Data Roaming
LyndseyM7127
Hi I’m going to Portugal On Tuesday. Can I use data roaming over there. I was in Liverpool a few weeks ago and it wouldn’t work for me over there. I have used it before while in England last year
Membership plans include EU/UK roaming allowances which should work.
