Porting from eir to 48 failed - eir say no problem their end
reak4256
My porting has been rejected from eir to 48 I’ve already prepaid 2 months balance in my 48 sim still it’s showing porting rejected I contacted eir and they said there’s no problem from their end idk what to do help me out !
Eir really should be able to tell you why it failed.
You might need to contact them again.
See also the porting guide:
Note that you can still use your membership now albeit using the new 089 number originally provided with the SIM and detailed on your account:
