Hotspot
Mingxuanz0779
Why I can’t give out my hotspot
What happens/goes wrong?
To use a hotspot on 48...
First make sure that you have an active membership, your APN settings are configured correctly, and mobile data works for web browsing and connected apps.
Second, configure your hotspot as normal:
If you're using an iPhone you may need to read this too - in particular the section titled "A note about personal hotspot setup on iPhones":
If you still have problems then you'll need to post back with detailed information about what you've tried, what's not working, any error messages you get, etc.
