03-03-2015 12:05 AM
03-03-2015 10:01 AM
What networks do you see when you manually scan for networks?
If you see 48 (or O2 if 48 not listed) then manually connect to that.
Do you need to disable roaming profile (i.e. the opposite to this)?
If that doesn't help then contact 48 support for assistance:
03-03-2015 10:15 AM
03-03-2015 10:27 AM
What phone are you using?
03-03-2015 11:03 AM
03-03-2015 12:12 PM
What about this?
What version of iOS are you using?
Have you tried just switching the phone off and on again or toggling airplane mode on and then off?
03-03-2015 03:27 PM
This link might also help?
Substitute 48 (or O2 if 48 is not listed) for "iinet":
https://iihelp.iinet.net.au/Troubleshooting_Mobile_Voice_-_Manually_select_Network_Carrier
